<p>Hello dear fellows,<br />
My question is a very naive about gas chiller for LPG recovery.<br />
I m simulating a C3 refrigeration loop, I placed a heater (as a chiller) to converge the loop. Once it is converged I replaced it with heat exchanger in order to bring gas feed for chilling.<br />
After getting it converged i have noticed that <strong>both the streams across heat exchangers are hot streams</strong> i.e. C3 temperature is also reducing as well as gas stream temperature is also reducing (which is supposed to be chilled).<br />
In any HX one stream is hot and other is cold. it means if Feed gas temperature is lowered than C3 refrigerant temp should rise.<br />
<br />
I have kept the C3 outlet stream as -4 F and at bubble point. and condenser outlet temperature as 122F at dewpoint.<br />
Can any one let me know why is that happening,<br />
i m attaching hysys simulation showing both HX and chiller (as heater).<br />
<br />
Responses are awaited<br />
Thanks.<br />
fire</p>
Propane Refrigeration Chiller
Started by Fire on dire, Jun 18 2012 07:31 PM
propane refrig chiller lpg
Posted 18 June 2012 - 07:31 PM
Posted 18 June 2012 - 07:43 PM
Hysys file is not uploading some problem saying i m not permitted to upload this kind of file.
sorry for the inconvenience but still any responses will be appreciated.
Posted 19 June 2012 - 07:11 AM
First of all, there are no attachments as you mention.
Secondly, your message is full of cryptic symbols - like BB Code; did you do this on purpose?
thirdly, this is obviously a simulation problem and it is in Refining, Oil & Gas Forum. It belongs in the Simulation Forum and that is where I am moving it so it can get the proper attention.
Posted 05 July 2012 - 02:15 AM
Change the extension of the file from .hsc to .doc and upload the same. Let us see where is the issue.
Posted 08 August 2012 - 08:43 PM
I can understand what you are describing, but i can not work out why.
It feels like you have specified something within the propane loop that is forcing the results you are seeing... i.e. propane stream getting colder.
have you specified a pressure drop across the exchanger on the propane side??
A pressure drop across the exchanger will result in the propane stream cooling.
For propane kettles, the pressure drop on the propane side is specified as 0, as it just considers the vapourising liquid propane.
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
