All,
when oil loading into cargo tank from 2nd stage seperator through a dip pipe in a FPSO, there is chance of gas blow by from 2nd stage seperator to cargo tank. the set pressure of 2nd stage seperator is 3.5barg and cargo tank is at 0.1barg. Gas blow byrate is 85000sm3/hr. Any way it is instantaneous flowrate, it will decrease with time.
I did some settle out calculation for this case, but settle out pressure is coming more than design pressure of cargo tank. So I need to depend on the liquid height in the tank and change is flow due to this hydrostatic head in the tank. I want to perform manual calculation rather than dynamic simulation. I am trying find some calculus formulas but I failed to find suitable one.
Please share with me if any ideas or formulas.
regards
srinivas
Posted 26 June 2012 - 07:08 PM
![]() Steam Sparger In Atmospheric Water TankStarted by Guest_owe_* , 16 May 2025 |
![]() Phosphoric Acid 56% Tank LiningStarted by Guest_Phosphoric123_* , 20 Apr 2025 |
![]() Tank Inlet Diffuser LengthStarted by Guest_RAFAELDAVE_0752_* , 08 Apr 2025 |
Discussion - Predict Storage Tank Heat Transfer Precisely By Jimmy D KStarted by Guest_raj shekhar_* , 25 Mar 2025 |
Tank Filing TimeStarted by Guest_not_mikhail_* , 17 Mar 2025 |
