I am checking if a thermal relief valve is required on the cold side of a new exchanger in case of the blocked-in condition. Isolating block valves are to be installed on the inlet & outlet lines of the cold stream to/from the exchmage. The following are the operating conditions:
Hot Side:
Fluid: Inhibited Water
Inlet Temperature: 85 C
Outlet Temperature: 33 C
Inlet Pressure: 370 Kpag
Design Pressure: 1,380 Kpag
Cold Side:
Fluid:Recycle Water
Inlet Temperature: 22 C
Outlet Temperature: 79 C
Inlet Pressure: 720 KPag
Design Pressure: 1,448 KPag
The design pressures are based on the maximum shut-off pressure of the pumps.
My analysis is that, a thermal relief valve is not necessary because, for the cold-side pressure to reach the design pressure of 1,448 KPag during blocked-in condition, the Recycle Water must attain a temperature of 200 C. Since the Inhibited Water temperature (heating medium) is only 85 C, it is not possible for the Recycle Water to have a temperature of 200 C.
Is my analysis proper? Please comment.
