Hi all,
Ion exchange is used in water treatment applications. However, I would like to know how anion exchange resins (hydroxide functional group) are regenerated during water treatment. Is there any literature or source I can look at on this matter? I've tried searching on my own, but I seem to fall short. I found that the conventional method is to use KOH/NaOH, but is there any other way to regenerate the anion resin? Thank you in advance for your help.
keby9vam
Regeneration Of Anion Exchange Resins
Started by keby9vam, Jul 03 2012 07:41 PM
Posted 03 July 2012 - 07:41 PM
Posted 04 July 2012 - 09:01 AM
In the "BETZ Handbook of Industrial Water Conditioning", published by Betz laboratories Inc (several editions), data on Ion exchange regeneration can be found in Chapter "Ion Exchange, Part 1" (Next Chapter "Ion Exchange Part 2" deals with zeolite softenig). However data in the book does not look more extensive than in http://nzic.org.nz/ChemProcesses/water/13D.pdf; nevertheless BETZ distinguishes between strongly / weakly acidic and basic resins, so BETS is judged more clear and complete than the mentioned link (but brief). Probably resin suppliers can supply more data and give info more precise than this from BETZ presented below.
1. Strongly basic anion resins (e.g. HCl+ZOH-->Z.Cl + H2O) are regenerated by "a strong alkali, such as caustic soda". Z.Cl + NaOH -->ZOH + NaCl. No other means is reported. I have not heard of anything else, in the few desalination units met in factories. So there is doubt whether another "strong alkali" option can be more economical, under usual conditions.
2. Weakly basic anion resins (containing amine groups, -NH2) are "regenerated by applying caustic soda, soda ash (Na2CO3), or ammonia". Regeneration efficiency is higher compared to strong basic anion resins.
It is noted that these resins can absorb free mineral acids (e.g. H2SO4, HCl), but cannot absorb weakly ionized acids (H2SiO3, H2CO3); so they are used in conjunction with strongly basic anion resins in demineralizer units to reduce operating cost.
3. Above comes from paper info, so data from actual experience would be welcomed.
Edited by kkala, 04 July 2012 - 09:06 AM.
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Zeolite Bed RegenerationStarted by Guest_TestTest_UK_* , 28 Jan 2024 |
