Cold Differential Test Pressure
Posted 10 July 2012 - 08:07 AM
As per API 526 sixth edition 2009,
cold differential test pressure=set pressure+manufacturer recommended temperature correction
my question is that,which temperature should be considered?
operating temperature,or relieving temperature?
regards
Rohollah
Posted 10 July 2012 - 08:37 AM
I just checked out Appendix-B of API STD 526 where "Cold Differential Test Pressure" is defined. My interpretation of temperature correction is based on the relieving temperature at the inlet of the relief valve and not on operating temperature since the definition clearly states that:
The pressure at which the pressure relief valve is adjusted to open on the test stand
Posted 11 July 2012 - 12:57 AM
I just checked out Appendix-B of API STD 526 where "Cold Differential Test Pressure" is defined. ....
Just minor correction: Appendix-A included above statement...
Posted 11 July 2012 - 11:24 AM
superimposed or built up backpressure?
regards
Rohollah
Posted 11 July 2012 - 03:36 PM
The definition is clear. Cold differential test pressure is when the relief valve opens on the test stand. On a test stand the relief valve is open to atmosphere, so the total backpressure is the sum of the superimposed backpressure (0 barg) plus the built-up back pressure.
Ankur
Posted 11 July 2012 - 10:16 PM
in terms of backpressure correction, which backpressure should be considered?
Rohollah,
It depends on the valve type:
-For conventional PSV it is just needed to consider correction for constant (or maximum variable) superimposed back pressure. Then, because in these valves in any case the build-up back pressure should be lower than allowable overpressure, no need to consider build-up back pressure in back pressure correction factor.
-For balanced bellows and pilot operated PSV's in the cases in which the build-up back pressure might increase the total back pressure such that exceeded the acceptable back pressure limits, then back pressure correction should be included build-up back pressure.
Fallah
Edited by fallah, 11 July 2012 - 10:18 PM.
Posted 12 July 2012 - 12:24 AM
First of all thanks for your good explanations.
it would be appreciated if you give me any reference for what you mentioned.
regards
Rohollah
Posted 12 July 2012 - 12:47 AM
Rohollah,
It is logical result could be got from PSV fundamentals along with the conditions at PSV test on relevant stand. If you have any doubt on my explanations let's know to explain a little bit more.
Fallah
Edited by fallah, 12 July 2012 - 12:49 AM.
Posted 12 July 2012 - 12:57 AM
Fallah
Rohollah,
Fallah
what do you mean by"in the cases in which the build-up back pressure might increase the total back pressure such that exceeded the acceptable back pressure limits"
does it mean,build-up back pressure should be considered in balanced bellows psv ,when back pressure>50% set pressure?
#10
Posted 12 July 2012 - 01:05 AM
Rohollah,
I meant when, let say, build-up back pressure may increase total back pressure for balanced bellows higher than 30% of the set pressure and for pilot operated higher than 50% of the set pressure.
Fallah
#11
Posted 12 July 2012 - 04:28 AM
As per API 520 part1 seventh edition- 3.3.3.2.1
max allowable back pressure for balanced psv is 50% set pressure.
but you mentioned 30%?
regards
Rohollah
#12
Posted 13 July 2012 - 05:03 AM
Rohollah,
I did want to clarify the concept. If you follow the API 520, you can get the value specified there.
Fallah
Edited by fallah, 13 July 2012 - 05:43 AM.
#13
Posted 13 July 2012 - 05:40 AM
Thanks for your help.
should temperature correction be considered for open bonnet psv?
Rohollah
#14
Posted 13 July 2012 - 05:48 AM
Rohollah,
As far as i know, there is no exception for temperature correction in bonnet type point of view.
Fallah
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
