Can anybody help me on how to estimate the temperature of mixed stream when there are two temperature streams mixing together; also in addition to that how to estimate the mixture heat capacity.
Thanks in advance,
RY
Estimating Resulting Mixture Temperature
Started by rahul22yadav, Jul 18 2012 12:52 AM
Posted 18 July 2012 - 12:52 AM
Posted 18 July 2012 - 03:22 AM
rahul,
What you are asking is elementary heat balance which is normally taught in 2nd year of chemical engineering.
Basis: Two Streams Mixing (Stream 1 & 2) and forming Mixed Stream 3
Mass flow rate of Stream 1: M1 kg/h
Enthalpy of Stream 1: H1 kJ/kg
Mass flow rate of Stream 2: M2 kg/h
Enthalpy of Stream 2: H2 kJ/kg
Mass flow rate of Stream 3: M3 kg/h
Enthalpy of Stream 3: H3 kJ/kg
Mass Balance:
M1 + M2 = M3 ...........................(1)
Heat Balance:
M1*H1 + M2*H2 = M3*H3 ...........(2)
Now solve the above two equations to obtain M3 & H3
To solve (1) & (2) you obviously need to know M1, M2, H1 & H2.
Once you know H3 for the mixed stream, the corresponding temperature can be read of a Mollier chart for the mixed stream.
Looks like I am back in my 2nd year of chemical engineering undergraduate course.
Mass Balance:
Heat Balance:
Edited by ankur2061, 18 July 2012 - 03:28 AM.
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Distillation Tower Top And Bottom Temperature And PressureStarted by Guest_student55_* , 27 Mar 2016 |
High Stack Temperature In Ccr HeatersStarted by Guest_viba0124_* , 30 Nov 2024 |
