Posted 19 July 2012 - 01:18 PM
Ashish:
My response to your further comments and questions is in red:
My process requirement is 115 oC 7kg/cm2 superheated water. I have availability of 160 oC - 180 oC superheated steam at 7 kg/cm2g.
There is no such a thing as “superheated water in a pure water system. You cannot heat a liquid beyond its boiling point at the pressure it is at. The hottest a liquid can get is its saturated temperature. Beyond this temperature and at the same pressure, it will revert to the vapor phase. In the case of water, this means steam. Your product water at 115 oC and 7 kg/cm2 is actually subcooled, not superheated. It is subcooled because it is at a lower temperature than its corresponding saturated temperature at that pressure.
Please suggest me how can I calculate steam required for this purpose.
As both DB Shah and I have suggested, there is another method used to obtain hot water by using steam – either saturated or superheated. But you have failed to tell us WHICH method you want to proceed with to produce your hot water.
I think first I will calculate the saturated steam requirement and then decrease it by approx 10% for its degree of superheat. What will be the heat transfer coefficient for this superheater.
This is not an acceptable calculation for the required steam flow rate. What is your engineering basis for doing it this way? All you have to do is make a heat and material balance around your heat exchange. This should be a very elementary and easy calculation.
Await your response.
