Posted 21 July 2012 - 09:29 AM
Digeca:
I would not employ cast iron as the material of construction for a liquefied propylene transfer pump. The cast iron, even though it might be "fine-grained", is susceptible to facture if stressed - for example, at the flanges or by an impact or blow struck from the outside. The nature of the fluid and the dire consequences that you would have to confront should that happen far out-weigh, in my opinion, the difference in cost by making the pump casing out of forged 316 SS. I use stainless not because of possible corrosion, but because of its inherent higher tensile strength at the lower temperatures. And the construction would be of forged - not cast - material, which is far more flexible and tolerant of localized stresses. You are going to suffer from piping and material stresses in your application due to the relative low temperature you have to employ to maintain your propylene as a liquid, so stainless would be a natural way to design around that. Do not forget that the normal design allowable stress on a pump's flanges is essentially zero ("nada").
