I have one doubt regarding relief requirement at the discharge of Positive displacement pump (rotary).
1. I have a rotary pump with casing design pressure at 16.0 Kg/cm2g, discharge piping design pressure at 13.0.
2. PSV is provided at the discharge piping to protect the pump and piping in case of inadvertent closure of discharge valve.
3. Also rated discharge pressure is 9.22 Kg/cm2a.
My doubt is that set pressure of PSV is given as 10.26 Kg/cm2g. - why so?
Why this set pressure is taken when casing and piping design pressure are quite higher than this.
Actually i am doing adequacy check for this PSV.
Thanks.
Edited by chiks, 19 July 2012 - 07:06 AM.
