I work for Bidco Oil Refineries Ltd, a leading edible fats and oils manufacturer in the East and Central Africa region. We recently installed a new solvent extraction plant for processing maize germ, sunflower and soyabeans. We have encountered a problem in determining the exact amount of hexane being used per metric tonne of oil seed processed.
I would appreciate any opinions or ideas on how best to go about solving this problem.
Yours truly,
Cyrus Karanja
Production Manager
Bidco-Elianto Division
Kenya.
email: cykar2000@yahoo.com
Determining Hexane Usage(loss) In A Solvent Extraction Plant
Started by Guest_Cyrus Karanja_*, Dec 13 2005 03:36 AM
Posted 13 December 2005 - 03:36 AM
Posted 14 December 2005 - 06:25 AM
Hi Cyrus,
I don't necessarily have any ideas about your problem but your question/request is not very clear. What exactly is the problem... predicting losses (calculating a mass balance), or trying to pinpoint and quantify losses around the plant against a known hexane make-up or something different?
Posted 16 December 2005 - 02:17 AM
Dear Colleagues,
We are an edible fats and oils refiner in Kenya serving the East and Central Africa region. We recently installed a new solvent plant, with a capacity of 100 MT/DAY, to process maize germ, soya bean and sunflower.
We have a problem in that have not been able to determine how much hexane is being lost within the system either through unidentified leakages or venting to the atmosphere.
At plant startup, we pumped in 19000 kgs of hexane. We have now run for 6 days (144hrs) and have not added any more hexane. Our target is to minimise the losses to at most 2 kg/MT of oilseed processed. I would welcome any suggestions on how best to go about designing a system for determining how much hexane is used (lost) on a 24 hour basis at the least cost and with the greatest accuracy.
Cyrus Karanja,
Production Manager,
Bidco-Elianto Division,
Kenya
E-mail : cykar2000@yahoo.com
Cyrus Karanja,
Production Manager,
Kenya
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
Prv Vs Extraction Condensing TurbineStarted by Guest_mj311_* , 13 Nov 2024 |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
