Importance Of L/d
#1 aliadnan
aliadnan
  • 88 posts
Posted 18 December 2005 - 04:45 AM
HI...
I want to know what is the importance of L/D ratio in the design of reactors, vessels dryers and other equipments. I would be very gratefull for your help
#2 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 19 December 2005 - 03:41 AM
It is difficult to give a general answer to your question, but the l/d ratio is Very important
Firstly, on a chemical engineering viewpoint, the larger the l/d, the closer to a plug flow behavior you will have. Very often, but not always a plugflow reactor is preferable to a perfectly mixed reactor (CSTR).
With a large l:d, also, for a given volume you increase the wall area, thus facilitating heat dissipation.
Secondly, you have economics. It is also clear that for quite large vessels or reactors a large l:d (cigar-like shape) is more expensive.
There is no clear cut answer. For a reactor the preffered choice depends on the kinetics of all the reactions, including the unwanted reactions. For a vessel a l:d of 2 to 3 is a good ratio.
#3 Ankur Shah
Ankur Shah
  • 77 posts
Posted 23 December 2005 - 03:55 AM
also,
if u have a higher L/D ratio for a packed bed reactor, u will induce higher pressure drops across it.
to get a proper L or D, u will need to optimise for the economics, the operation and the requirement of the system.
Ankur
