By referring to your spreadsheet named “Producing and maintaining vacuum” , attached to post http://www.cheresour...cuum#entry51027
, finally in page “Equipment sizing “ , in case of vacuum pump with vent condenser , you have given below data as the Vacuum pump suction spec:
Air seepage +water vapor flow: 35 Acfm
Vacuum Press 0.95 inHg (total press)
Temp : 25 OC
Do you mean that I shall order a Vacuum Pump with above flow, press and temp?
If so , I got confusion , as the amount of individual Air seepage by itself is 18.4 lb/h (calculated in page “Sizing Example Problem”) so that such an air seepage will have a volumetric flow rate of 131Acfm at above conditions, as per Dalton Law!! So shall I order a vacuum pump with this flow instead of 35Acfm??
In fact , I believe that if the Vacuum press at suction side of vacuum pump is the same 3.5 in Hg, the air +water vapor flow of 35 Acfm seems OK.
Could you please clarify?
Attached please find my comments.
Edited by Araboni, 01 August 2012 - 05:57 AM.
