Posted 06 August 2012 - 12:06 AM
Dear Afshin-
Firstly, I will request you to furnish your query with some background & simple sketch, as absence of which may not give you right answer.
Well, as understood by me, the scheme has an atmospheric tank storage at pump suction with existing pump delivering to its destination, which has now been elevated by 8 m. It is required to find out optimum solution to cater for this change. Please confirm my understanding.
Now, firstly note that for installing booster pump doesnot require any buffer tank & same can be installed inline. Secondly, since you have not mentioned flow rate, you need to collect information about availability of pump model, since rise in differential head is just marginal. In view of this, you may try following option.
1. Review the existing pump curve & check if bigger impeller size can fulfill the requirement & available pump model as well as motor is sufficient to accomodate the revise duty.
2. Check possibility of using higher rpm motor, which will definately rise differential head.
3. Reperform hydraulics to check whether there is margin on head & also check effect of increase in discharge pressure because of rise in elevation on flow & check if it is acceptable.
4. At last option, instead of installing booster pump, review possibility of changing existing pump itself.
Hope, this will help you.
