I am working on Bitumen production from wellpad at pressure of 4200 and temperature of 200degree C. We want an instrument that will measure the pressure within this line. The conventional instrument for measuring Pressure cannot be used because of freezing.
Does anybody have the optimum instrument to use for this fluid?
I will be glad if this can be shared at the forum.
Pressure Measurement On Bitumen Pipeline
Started by 'Diran Babalola, Dec 21 2005 04:48 PM
Posted 21 December 2005 - 04:48 PM
Posted 31 January 2006 - 11:56 AM
Can you insulate and heat trace the instrument?
Posted 28 March 2008 - 02:58 PM
Assuming this is 4200 psi I would suggest a melt pressure sensor which can withstand the temperature and has a flush diaphragm to prevent clogging when the media cools, you can view some examples here: Melt Pressure Sensors
Posted 29 March 2008 - 08:50 AM
I remember working for a short time on bitumen blowing unit, where the minimum transport temperature of final product to the storage tank was specified to be 120C (high pour point). All instruments were insulated and heat traced, as suggested by Paul. You can choose between steam tracing or electrical, self-regulating heat tracing - and I strongly recommend the latter one due to its reliability.
In some occasions it is possible to use glycol-filled instruments, but I think this is not so good practice when having extremely heavy petroleum products.
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Heavy Oil/bitumen UpgradingStarted by Guest_scantx_* , 19 Dec 2025 |
