For a tube side condensing shell and tube heat exchanger would you recommended using 3/4" or 1" tube.
Also, what is the maximum two-phase velocity inside the tubes that the heat exchanger should be designed for?
Cooling water is limited to 2.5 m/s but have not seen any guidelines for two-phase flow to avoid tube erosions.
Tubes are carbone steel
Horizontal Shell And Tube Heat Exchanger - Tube Side Condensing
Started by azarhojabr, Aug 12 2012 04:30 PM
Posted 12 August 2012 - 04:30 PM
Posted 12 August 2012 - 08:34 PM
Azarhojabr:
It is very difficult to respond to your query when you fail to cite specific information regarding:
- Is this a pending process design?
- What configuration are you proposing? Is it horizontal or vertical? Is it a straight tube, shell and tube unit or a kettle with a U-tube bundle?
- Give a drawing of the proposed installation to see how you propose to vent non-condensables and drain off the condensed product.
- What are you condensing?
Posted 13 August 2012 - 09:19 PM
it is for a new design
horizontal heat exchanger BEM type
I would like to know if 3/4" or 1" tube is recomnmended. Also, what is the maximum tube velocity for a condensing service?
Posted 14 August 2012 - 09:48 AM
azarhojabr:
Please give a drawing of proposed Installation with condensate pipe lining and the questions of Art Montemayor
Posted 20 August 2012 - 07:15 PM
I have tried to give the OP some basic clues regarding his insistence on using a horizontal (un-sloped) BEM with condensation inside the tubes. He is going to confront a lot of problems trying to drain the condensate in a steady manner out of such a configuration – especially if he tries to use multi-passes on the tube side.
The size of tube employed or tube side velocity will have little effect on the bad results.
Oh well, that is one way to learn about process heat transfer design.
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
