Dear all,
How do I determine the fuel gas requirement for a gas turbine generator? It is a 4MW generator load and efficiency of 31.5%.
Fuel Gas Consumption
Started by asade abiodun, Aug 24 2012 07:42 AM
Posted 24 August 2012 - 07:42 AM
Posted 24 August 2012 - 07:53 AM
Posted 27 August 2012 - 01:06 PM
Asade,
What do you mean by Requirement, is it some kind of parameter ?
Provide more details.
Attached some documents, may be you will find helpful.
Shivshankar
Shivshankar
Edited by Shivshankar, 27 August 2012 - 01:23 PM.
Posted 29 August 2012 - 04:33 PM
Asade,
I don't understand the difficulty with this simple question. Your statement
Efficiency of 31.5% means that the power of 4 MW is 31.5% of the heat released when the fuel is burnt. From this you can calculate the total heat released by the fuel = 4 MW/0.315
Now divide this result by the NETT (lower) calorific value of the fuel gas, and you will have the fuel gas flowrate required.I leave it to you to get the units correct.
Paul.
should make the answer obvious.It is a 4MW generator load and efficiency of 31.5%
Paul.
Posted 30 August 2012 - 01:51 AM
paulhorth,
thanks for the clarification. I have calculated the fuel consumption based on the total heat generated.
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
