I am about to carry out the leak test of HDT reactor and other High Pressure systems at 70 kg pressure with Hydrogen, in newly constructed project, before start-up. The MDMT given by manufracturer is 16 deg C and MPT is 80 deg C. It is difficult to carry out the leak of system at 80 deg C with soap solution, if I have to follow the MPT.
In my earlier projects of similar kinds, I had not used MPT for leak test and leak test was carried out at ambient temperature only.
My question is wheteher I have to follow the MPT requirement or MDMT for the initial leak test ?
If MPT needs to be followed strictly, what method I have to use for detcting the leaks in the system ?
Please Guide me.
No replies to this topic
Posted 24 August 2012 - 11:13 PM
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Distillation Tower Top And Bottom Temperature And PressureStarted by Guest_student55_* , 27 Mar 2016 |
