Hey all!..can you please suggest the best fluid mechanics book which can understand easily? I have a book written by franzini,finnemore but that's very hard for me to understand.
Advance thanks & greetings!
Fluid Mechanics Books
Started by mehedi, Aug 26 2012 03:58 PM
Posted 26 August 2012 - 03:58 PM
Posted 26 August 2012 - 07:02 PM
Hi Mehedi,
Go to the library and take a look at :
Note : a free ebook for pump & system: http://www.pumpfunda...m/pump_book.htm
Hope this helps .
Good luck.
- Chemical engineering Fluid mechanic 2nd edition revised and expandedv by Ron Darby
- Engineering fluid Mechanic 9th edition by Clayton T Crowe, Donald F Elger , Barbara C,Williams , John Roberson - Willey
- Fluid mechanic worked examples for engineers IchemE by Carl Schaschke.
Hope this helps .
Good luck.
Edited by breizh, 26 August 2012 - 11:10 PM.
Posted 27 August 2012 - 12:10 AM
Get Fluid Mechanics by Munson Shapiro.
Shivshanakr
Shivshanakr
Posted 27 August 2012 - 07:05 PM
All Chemical Engineering Students:
Once again, Breizh has pulled a rabbit out of his hat! I have been looking for the lost website of Jacques Chaurette for some time now. He has changed his websites through the years, but he still offers his great pump book to all who seek knowledge in pumping fluids. If you want to improve your knowledge and your career, download this book - but be sure to read every page until you thoroughly understand everything he writes.
Breizh, may your tribe increase.
Posted 28 August 2012 - 03:32 PM
thank you very very much breizh for your suggestion and of course specially for the book about pump.
also a very much thanks to shivshankar and art.
i always respect you all!
regards!
regards!
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
Excel Based Calculator For Fluid Bed DryersStarted by Guest_outcast_* , 15 Mar 2023 |
