Hi, Could any body suggest me what will be the air compressor capacity (CFM) to produce 40 NM3/Hr of nitrogen having 0.5 % Oxygen content?
Air Compressor Capacity For 40 Nm3/hr Nitrogen Plant
Started by vijji, Aug 27 2012 11:02 AM
Posted 27 August 2012 - 11:02 AM
Posted 27 August 2012 - 12:30 PM
Reddy,
Hope attached documents helps you.
Shivshankar
Shivshankar
Posted 29 August 2012 - 04:50 AM
WIth O2 limit of 0.5% & low requirement a small PSA/membrane unit will suffice.
kindly refer:-
http://www.cheresour...mption-figures/
kindly refer:-
Posted 29 August 2012 - 12:29 PM
Hi all, my question is very simple, what could be the air compressor capacity-CFM to get nitrogen 40 NM3/Hr. If any thump rule please....
Posted 29 August 2012 - 12:37 PM
Basis: 100 kg-moles of air
Nitrogen: 79 kg-moles
Oxygen: 21 kg-moles
Mole Percent = Volume Percent
You can calculate the Air Volume rate now.
Oxygen: 21 kg-moles
Posted 29 August 2012 - 11:29 PM
Dear Reddy
If your question was that simple, Ankur's reply is perfect. Why do you need thumb rule, this is a plain stochio calculation.
If this isnt just an acadamic query, kindly refer the link where Ankur, Zauberberg and Breiz have given some insight.
Refrigerated Storage Tank Vaccum Breaker CapacityStarted by Guest_Lyne_* , Yesterday, 08:11 AM |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , Today, 02:00 AM |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
![]() Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
