Relief Valve Discharge Piping
Posted 29 August 2012 - 04:01 PM
Thank you
Posted 29 August 2012 - 04:41 PM
Yes, that's right, it is.I realize there is an orifice that cuts down the pressure but is the pressure cut that much?
The pressure downstream of a relief valve is determined by the downstream system and piping, not by the upstream pressure. The downstream piping should be designed so that the pressure at the valve outlet at full flowrate is no more than 10% of the set pressure (for a conventional spring operated valve). This is a code requirement. So, for your 1400psi set point this would be 140 psi which is well within the limit of 150 # flanges.
Paul
Paul
Edited by paulhorth, 29 August 2012 - 04:43 PM.
Posted 29 August 2012 - 05:22 PM
Posted 29 August 2012 - 07:20 PM
Class 150. However, higher flange class ratings may be required when the PRV discharge is to a closed system.
The reason is because the discharge pressure operating is around 30-50 psig hence the design pressure of the main header should not be higher that 100 psig
Posted 29 August 2012 - 08:01 PM
Nertil,
Paul
Paul
what section of api 520 is that stated in?
How would this apply for a pilot operated valve?
Edited by nertil1, 29 August 2012 - 08:02 PM.
Posted 29 August 2012 - 08:07 PM
Remember that a pilot operated valve is normally used for processes that expect a higher backpressure (around >50%) so your relieving pressure is not high in the 1st place.How would this apply for a pilot operated valve?
Your flare stack is essentially atmospheric and any increase in pressure in your flare network comes from basically the backpressure of your flare discharge, which I doubt will require more than 150# rating.
Posted 29 August 2012 - 10:04 PM
Well, that's not necessarily true. We will use pilot valves to have tighter shutoff and a more controlled release (modulating pilot). The relieving pressure is still high (we have some pilot PRV that relieve at 2100 psig). These reliefs are actually vented to atmosphere
Posted 29 August 2012 - 10:36 PM
As I quote Mr Paulhorth (bold for emphasis):
The only way the discharge pressure of a relief will increase is if you experience an increase in backpressure, which will only come from other relief valves relieving (increase in destination pressure is out of the question if you're flaring to atmosphere).The pressure downstream of a relief valve is determined by the downstream system and piping, not by the upstream pressure. The downstream piping should be designed so that the pressure at the valve outlet at full flowrate is no more than 10% of the set pressure (for a conventional spring operated valve). This is a code requirement. So, for your 1400psi set point this would be 140 psi which is well within the limit of 150 # flanges.
Paul
Edited by Dacs, 29 August 2012 - 10:36 PM.
Posted 30 August 2012 - 12:38 AM
Increasing the back pressure in discharge line of a PSV (especially in conventional type), even excessive from allowable value, might also occur due to choking at the PSV outlet flange regardless of piping size, route and length.
Edited by fallah, 30 August 2012 - 12:40 AM.
#10
Posted 30 August 2012 - 12:40 AM
#11
Posted 30 August 2012 - 01:03 AM
I agree with that, but I guess it might happen if the lateral is undersized to the point of having choked flow.
Not related, it can be occured even for zero tailpipe length.
#12
Posted 30 August 2012 - 01:55 AM
However, flare piping apart from PSV mating flange is always 150# for economic reasons. This is not dictated by API. For given relief rate and flare tip pressure drop, we select flare piping diameter that results in 150# piping. Most of the times, flare headet mach number criteria automatically meets 150# criteria.
Sachin
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
