to all,
I need your help. I am evaluating the PSV and Rupture disc for the current dispersers. the fire case calculation has been done, but I need to calculate the required flowrate for the PSV and Rupture Disc in case there is a runaway reaction. Please help me to show me the calculation for required flowrate for runaway reation that allows me to determine the PSV and Rupture Disc.
thanks
How To Calculate The Required Flowrate For Psv And Rupture Disk
Started by Hai, Sep 08 2012 09:25 AM
Posted 08 September 2012 - 09:25 AM
Posted 09 September 2012 - 01:49 AM
Hai,
It is a complex phenomena and relieving rate determination for a runaway reaction absolutely depends on reaction degree, nature, rate,... and state of reaction products. I would want to refer you to sec. 3.4. Vent Rate for Reacting Systems; from "Gudelines for Pressure Relief and Effluent Handling Systems".
Fallah
Fallah
Posted 09 September 2012 - 06:34 AM
Hai,
Take a look at this link and the cases studied . Regarding Run away reactions you will find information about the required basic data , in particular the energy using Thermogram .
http://www.safety-s2...4&op=v&idp=1522
Hope this helps
Hope this helps
Posted 09 September 2012 - 11:01 AM
thanks all.. i will study your information..
Posted 10 September 2012 - 07:53 AM
Hai,
Run away reactions are very compIex as stated above, generally reactor are licensed unit.
There are a lot of assumption to be done in runaway reactions that might be tricky, they also may depend on the dynamic of the system and the complexity of secondary reactions.
Plus you have the accuracy of EOS, the accuracy of the model for reaction the that takes place, the nature of reactants and equilibrium may also change at relieving conditions.
In my point of view, there is a lot of incertitude while sizing PSVs for run away reaction, so I prefer not to take the risk.
Remember the fundamental rule of computer simulation:
bad input= bad output
I do not know the nature of your runaway reaction but if it is complex and you are working for an engineering, the best and safest approach is to ask the Licensor.
Edited by Mark-TR, 10 September 2012 - 08:39 AM.
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() Rupture DiscStarted by Guest_sima-f_* , 29 Jul 2025 |
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
