Can you please clarify the following points:
- Is the difference between control & choke valves. I believe difference is purely on pressure rating (i.e Control valves are available upto 2500 class whereas choke valves are available upto 4500 class or API 10000 or 15000).
- Internals(trims), I believe, mostly Ceramic or tungsten carbide are offered by both kind of valves.So there is no big difference here.
- Valve design : I think both (Control & Choke) offer angle and globe designs, but predominantly angle is preferred for HP or well heads.
- Control valve vendors offers multi step angle valves for HP applications(like Emerson's Notchflo/DST,Dresser Lincoln log etc, but choke valve manufacturers offer various cage designs to labynith trims (like CCI drag or Severn Glocon's MLT).
Is there any other major difference I should consider while selecting a choke valve.
Iyer
