I have to performe a mass and energy balance on the electrolysis of water. I know this might be obvious for most of you but I am confused when dealing with the energy part:
First that all, I am not really sure about the equations I need to use, I found different half equations depending on the type of electrolyte is used. I would run my calculation on a conventional (KOH) electrolyte.
I understand that in order to produce 1 kg of Hydrogen (H2) I need between (50-65 kWh of energy) depending on the electrolyser efficiency.
I also found that the oxidation taking place on the anode has the follow equation:
2H2O(l)------> O2(g) + 4H+(aq) + 4e- Eoox = 1.23 V
What is the relationship between the 1.23 V and the 50-65 kWh of energy?
For the mass part can I say that if I use 18 kg of H2O I get 4 kg of H2?
Could you recommend any text book or website that can help me undestand this topic.
Thank you in advance for your suggestions and help.
Kind Regards,
Kevin
Edited by heisenberg, 11 September 2012 - 10:47 AM.
