Hello:
does the pressure gage on any flow line represent the value of the static pressure.? Why?
Pressure Gage
Started by Manhal, Jan 04 2006 02:45 PM
Posted 04 January 2006 - 02:45 PM
Posted 06 January 2006 - 07:19 PM
Manhal,
I'd say the answer to your question is "yes". Typically pressure gauges are installed into the side of a pipe (or vessel) with the intention of measuring the static pressure at that point. In our business, we are seldom concerned with any other type of pressure, although we may be concerned with pressure differentials across flow measurement elements. Having been briefly exposed to some aeronautical engineers in the past, I know that in their business dynamic pressures and total pressures are important, and they do a much better job than Chem E's in defining the type of pressure they mean.
Doug
Doug
Posted 07 January 2006 - 09:05 AM
Hello Doug
again, I'd like to thank you for spending your time to reply my questions
Manhal
Manhal
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
