Hi all,
I have conducted a deltaP measurement on our pilot scrubber during operation. The results was 450 mm H2O.
I am not sure I understand the result, since 1 atm=10m of water. How should i analyse the result? Does it mean that the system is in "under-pressure" as in vacume?
U Tube Column Results Analysis
Started by RomanKatz, Oct 01 2012 02:02 PM
Posted 01 October 2012 - 02:02 PM
Posted 01 October 2012 - 05:57 PM
It means that the head loss through the packing is 450 mm H2O .In other words if the pressure at the top of the column is atmospherical pressure , it will be # 1.0435 atm at the bottom
Edited by breizh, 01 October 2012 - 05:59 PM.
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
