Time Required To Evacuate Vessel
#1 S.R.Shah
S.R.Shah
  • 113 posts
Posted 06 October 2012 - 10:22 AM
Hi;
How to calculate to evacuate 1 KL Vessel to 1mm Absolute pressure from Atmospheric vessel with Fixed capacity of Vacuum Source say 5000 lpm at 25 Deg C.
Specific Volume of Air Increases as pressure reduces.(Density= Pressure in Bar X Molecular Wt. in Kg/Kg Mole/Uni .Gas Constant x Temperature in Deg K).By calculating at equal Increments of Pressure ,and summing up total time,One can come to final time.I used this methos but time taken came quite long app. 10 Hrrs.
Please also find excel Spread sheet.Please correct.
Can anybody give any good reference?
Thanks in Advance.
SRShah
#2 Bobby Strain
Posted 06 October 2012 - 02:51 PM
Look here. http://www.engineeri...time-d_844.html
#3 S.R.Shah
S.R.Shah
  • 113 posts
Posted 06 October 2012 - 08:21 PM
Bobby;
Thanking you.
Can you correct me in my calculations?
I have included calculations by Formula in my excel sheet.
SRshah
#4 breizh
  • 6,786 posts
Posted 06 October 2012 - 10:10 PM
http://www.vacuum-gu.../technikfaq.htm
An other resource , take account possible leak like gasket , metal porosity .....
should be less than few minutes :t= 1000/5000*ln(1013/1).
Edited by breizh, 06 October 2012 - 11:40 PM.
#5 S.R.Shah
S.R.Shah
  • 113 posts
Posted 07 October 2012 - 02:41 AM
Thanks Bobby and Breiz.
I realised my mistake in spreadsheet.
Will you please give thumrule for selection of apprpriate vacuum system for volume of tank?
SRShah
#6 breizh
  • 6,786 posts
Posted 07 October 2012 - 04:01 AM
You may consider talking to vendors like Edwards Sihi, Bush, or local vendors for vacuum pums. Several technolgies are available like dry vacuum pump or liquid ring pump - even steam ejectors.
Now for calculation you should refer to a worksheet issued by Art Montemayor.
hope this helps
#7 S.R.Shah
S.R.Shah
  • 113 posts
Posted 07 October 2012 - 10:52 AM
Thanking you Briezh and Art.
SRShah
