Hello all,
I'm currently trying to size an adsorption column for my design project. In one of the references I looked up (http://www.wbdg.org/...dg_1110_1_2.pdf), they had the hyrdaulic loading rate as one of their design parameters. To my understanding the HRT is the design capacity(flow) divided by an area. My question is what is this area? Is it the total surface area on the polymeric resin that I will be using or is the the cross sectional area of the resin bed? The resin I use has a surface area of 1100 m2/g which is very large and will give me a very small HRT if I use it ( well below the usual 80-240 gpm/ft2 ).
The contaminants that will be adsorbed are: phenol, benzene and PAHs.
Blok
Hydraulic Loading Rate For An Adsorption Column
Started by BLok, Oct 06 2012 04:11 PM
No replies to this topic
Posted 06 October 2012 - 04:11 PM
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
