Problem With Heatflux Distribution Of Fired Heater Of Coker
heatflux distribution of fire
#1 Krunal Shah
Krunal Shah
  • 19 posts
Posted 13 October 2012 - 11:31 AM
Hello
Our plant has a double fired heater, but we have a problem that heat flux distribution is not same through out the heater..can any one tell me what are the reasons for that...??
I found following, please tell me if any other reason may be possible..
1. Pressure difference of Fuel Gas,
2. improper flue gas draft
#2 SSWBoy
SSWBoy
  • 58 posts
Posted 15 November 2012 - 03:49 PM
Need a lot more information here to help ...
- Firebox design, cabin, cylindrical etc.
- Burner type, number, arrangement
- Arrangement of process side, one pass or many pass's ?
- How do you know the heat flux is not even?
Some things that spring to mind are i) undersized fuel gas header to burners ii) different air register setting on burners iii) uneven process flow iv) tramp air into firebox
Sadly at the moment your request is so vague there could be any number of problems!
