Hello Everyone,
I am trying to convert the Filter differential pressure drop (3 psi) to a K-value. This way the DP changes with the flow rate. Does anyone know the Specific DP to K value formula for FILTERs? Thank you very much for your help.
Vali
Convert Pressure Drop To K-value
Started by Guest_Vali_*, Jan 10 2006 10:16 PM
Guest_Vali_*
Posted 10 January 2006 - 10:16 PM
Guest_Guest_*
Posted 23 January 2006 - 09:44 PM
I am surprised. No one knows the answer...Or is this just a stupid question?
Posted 24 January 2006 - 02:33 PM
The "K" factor is related to the pipe size of the fitting, or more specifically the velocity in the line.
K=2gh / v^2
where h is head loss in feet
and v is fps
There is a nice discussion of this in Crane TP410, which I recommend.
K=2gh / v^2
and v is fps
Posted 25 January 2006 - 02:19 AM
Hi proinwv
I have heard a lot about the Crane TP401. Is there any site from which I can get the electronic version of this paper? Do you have a PDF copy of this paper? I will gratefull I you help me in providing this technical paper.
Posted 25 January 2006 - 04:21 AM
You can buy the paper version of Crane TP 410 at http://store.vervant...t...l Paper 410 . As far as I know there are no (legal) electronic versions available...
Posted 25 January 2006 - 08:28 AM
Gvdlans is correct about where to get the book.
If you will do any fluid flow work, the price is a bargain. I might add that there also is software available from http://www.abzinc.com/ which appears to be excellent. I have not tried that yet, only because of economics.
Best to you,
Best to you,
Posted 12 April 2012 - 10:51 AM
It is neccessary to buy this book, this book will help you all time in your work
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
