Posted 18 October 2012 - 09:03 AM
Posted 18 October 2012 - 12:21 PM
Besides 70 km/h (=19.44 m/s) seems to concern air velocity, with corresponding flow rate 19.44*π*10^2/4=1527 m3/s.
This velocity is common for air; tunnel will cause a small ΔP, probably around 0.2 Atm. Assuming atmospheric pressure at the end of the tunnel, pressure at discharge of the compressor (I imagine fans) would be around 0.2 Atm g.
Please confirm or explain otherwise, to clarify the case.
Posted 20 October 2012 - 02:20 AM
Thank you so much, Yes, according to my requirement i need an air density of 100kg/m3Can you please check mentioned air density of 100 kg/m3, or give explanations? Atmospheric air at usual ambient temperatures has density around 1.2 kg/m3; assuming nearly isothermal flow, 100 kg/m3 would correspond to ~83 Atma.
Posted 25 October 2012 - 08:26 AM
Posted 25 October 2012 - 09:15 AM
See if atatched file helps.
Shivshankar
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
