I have to design a thickener fot underflow Mg(OH)2 slurry in brine solution containing CaCl2 and water with small quantity of NaCl, KCl. Feed slurry to thickener is approx. 7000kg/hr, underflow is 2200kg/hr. which parameter and proprties of Mg(OH)2 needed also which formula will be useful to find size (i.e. area, depth and dia) of thickener. how the rake mechnism will design by what formul. please help.
Posted 21 October 2012 - 12:40 AM
Posted 27 October 2012 - 10:36 PM
Posted 29 October 2012 - 11:24 AM
please give, experimental or lab test data of cake resistance for magnesium hydroxide cake for filtration in a rotary drum filter
also give laboratory or experimental data for concentration vs. settling velocity of 40% Mg(OH)2 slurry in CaCl2 solution. as it is useful in rotary drum and thickener design as they are part of my assignment. thanking you
Posted 29 October 2012 - 05:37 PM
Some info there : http://www.pacontrol...on 93851_11.pdf
As part of your assignment you have probably to perform tests to get data !
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
