Liquid Cross Sectional Area For Liquid Of Horizontal Vessel
#1 bhalchandra1986
bhalchandra1986
  • 8 posts
Posted 31 October 2012 - 04:13 AM
Dear Sir,
In attached horizontal tank volume calculation sheet (Horizontal storage tank heat loss calc- 03.01.2011.XLS) ,which formula is used for estimating liquid cross sectional area.
R = 1.495 m ; h =1.378 m for 45% filled volume.
By using this formula im getting Liquid cross sectional area as 190 m2.
Af = R^2 x COS-1 ((R-h)/h) - (R-h)x sqrt(2Rh - h^2) _______(from Reference sheet of 73456122- Vessel volumes.XLS)
Whereas as per calculation sheet it is 3.16 m2.
Please clarify.
Edited by bhalchandra1986, 31 October 2012 - 04:17 AM.
  • 1,631 posts
Posted 31 October 2012 - 06:29 AM
Your spreadsheet attachment did not appear. But check the units. I suspect the 190 is in cubic meters to represent the vessel volume (?) while the 3.16 square meters is the area of the liquid vertical cross section.
You are right to ask questions about results that look unreasonable. Any time I work from another's spreadsheet, I always am more comfortable stepping through each of the calculations to thoroughly understand the origin and use of each equation. It can be tedious, but I have made enough mistakes myself to blindly trust that the author of the spreadsheet made no errors. Sometimes a short cut is to compare the results to a known standard.
By the way, I think your formula should be:
Af = R^2 x COS-1 ((R-h)/R) - (R-h)x sqrt(2Rh - h^2)
Edited by Pilesar, 31 October 2012 - 07:10 AM.
#3 breizh
  • 6,921 posts
Posted 31 October 2012 - 06:38 AM
http://www.arachnoid...Calc/index.html
Consider this resource to support your calculations, if needed .
Edited by breizh, 31 October 2012 - 07:15 PM.
#4 Bobby Strain
Posted 31 October 2012 - 10:16 AM
You can check your answers with software at bobby-strain-group.com.
