Deaerator Evaporation Loss
Started by ssengr62, Nov 05 2012 05:21 AM
7 replies to this topic
Posted 05 November 2012 - 05:21 AM
Dear all,
I hope you are fine.
I have been given some assignment. We have water in deaerator and we want to evaporate this by spargin steam through the sparger.
Deaerator size 5830mm ID x 21800T/T.
Steam available at 144 deg C and 5.5 bar.g through 4inch line.
Is it possible to evaporate water through deaerator by using this steam.
How can I calculate?
Urgent help needed.
Thank you
Best Regards
Sajid
Urgent help needed.
Thank you
Best Regards
Sajid
Posted 05 November 2012 - 06:34 AM
http://www.spiraxsar...-deaerators.asp
Consider this resource , it might helps you.
Note : Consider this link to support additional needs:
http:// www.spiraxsarco.com
Posted 06 November 2012 - 01:32 AM
Deaerator is meant to dislodge oxygen and non condensables (inerts, Co2/N2) from Feed water -not to evaporate water.
First , you must know the principles of Deaeration.
Pressurised Deaerator pressure is o.2 bar g which corresponds to Tsat =105 Deg C.
Deaerator removes O2 , to ensure that O2 concentration is 7 parts per billion minimum. Deaerator is an equipment designed to combat corrosion contributor Oxygen.
Steam is required just to ensure the said temp. is maintained.
O2 and other non condensable gases are vented out from D.A through properly sized vent nozzle
Steam required may be around 3% of Boiler capacity. Of course , you can always arrive at this by H& M balance. So Deaerator is not an evaporator.
Posted 06 November 2012 - 03:40 AM
Equation Cited is the mass / heat balance equation used for this purpose.
Equation
Where:
To calculate the required steam flowrate, Equation is transposed to solve for
Equation
Example- Determine the amount of steam needed to heat a deaerator
Typical pressurised deaerator installation
An existing boiler plant is fed with feedwater at a temperature of 85°C. Due to the rising cost of chemical treatment, it is proposed that a pressurised deaerator be installed, operating at 0.2 bar g to raise the feedwater temperature to 105°C, reducing the solubility of oxygen to quantities typically measured in parts per billion. Steam, produced in the boiler at 10 bar g, is to be used as the heating agent. If the 'From and At' rating of the boiler plant is 10 tonne / h, determine the flowrate of steam required to heat the deaerator.
Where:
Boiler 'From and At' rating = 10 000 kg / h
Initial feedwater temperature = 85°C
Initial feedwater enthalpy at 85°C (h1) = 356 kJ / kg (from steam tables)
Boiler pressure = 10 bar g
Enthalpy of saturated steam at 10 bar g (hg) = 2 781 kJ / kg
Before any calculations can be made to estimate the size of the deaerator, it is important to know the maximum likely feedwater requirement. This is determined by calculating the boiler(s') maximum useful steaming rate, which in turn, depends on the initial feedwater temperature. The maximum steaming rate is found by determining the Boiler Evaporation Factor
Where:
A = Specific enthalpy of evaporation at atmospheric pressure is 2 258 kJ / kg
B = Specific enthalpy of saturated steam at boiler pressure (hg) in (kJ / kg)
C = Specific enthalpy of the feedwater (h1) in (kJ / kg)
Equation shown is used to find the required amount of steam to heat the deaerator.
From steam tables;
Enthalpy of feedwater at the required temperature of 105°C (h2) = 440 kJ / kg
Enthalpy of steam supplying the control valve @ 10 bar g (hg) = 2 781 kJ / kg
From above;
Enthalpy of the feedwater at say 85°C (h1) = 356 kJ / kg
Mass flowrate of water make-up to deaerator (
Therefore, the control valve has to be able to supply 334 kg / h of steam with a supply pressure of 10 bar g, and with a downstream pressure of 0.2 bar g.
ACK:
Thanks to Spirax sarco for their site info
Posted 08 November 2012 - 10:42 PM
Deaerator is filled with water
Capacity of Drum
tons
Quantity of water in tank at 28 C
tons
Quantity of steam required at 155 C
tons
Steam flow rate from 4" line
tons/hr
Total time required to evaporate water
hr
days
I answered my boss like as above. Actually the idea of my my boss was to evaporate and blow the 18" line at the top of evaporator that was impossible becuase even though we evaporate we cannot have so high velocity to blow the line.
Thank you so much for all you.
35
Capacity of Drum
990
tons
347
tons
4000
tons
8.25
tons/hr
485
hr
20
days
Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024 |
Pressure Drop Due To Entry Loss At Liquid And Gases Inside The ColumnStarted by Guest_SANDEEPCH_* , 24 Oct 2024 |
![]() Multiple Effect Evaporation 5 Stage CalculationStarted by Guest_pentakota.koti_* , 26 Jun 2018 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
