I need low pressure molding solution for sensitive electrical equipment that can be protect from humidity and moisture.
Posted 17 November 2012 - 06:26 AM
Posted 17 November 2012 - 07:48 AM
Macromelt® Low Pressure Molding Materials are thermoplastic polyamides which are used for total water-tight sealing of highly sensitive electrical and electronic components through molding process. It is known as guards against mechanical damage, and seals from dust and dirt also protect electronic component from from humidity and moisture.
