What will be the temperature of natural gas in an iron pipe, in gas distribution network? Following are the attributes considered.
1. Iron pipe of 3 inch to 6 inch diameter
2. 5 to 6 feet depth
3. Heated to take care of pressure reduction
4. Soil type varies accross the network.
Also if pre heated how long it will take to convert the temperature to normal ground temperature?
On a day when the atmostphere temperature is changing from 0 degree to 10 degree, will there be a temperature difference that will be noticeable in the pipe, based on the temperature coefficient?
Temperature Of Natural Gas In Distribution Network
Started by SubbuVenkat, Dec 03 2012 11:17 AM
gas temp coeffcient gas temp in distribution
Posted 03 December 2012 - 11:17 AM
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Distillation Tower Top And Bottom Temperature And PressureStarted by Guest_student55_* , 27 Mar 2016 |
![]() High Stack Temperature In Ccr HeatersStarted by Guest_viba0124_* , 30 Nov 2024 |
Cross Over Temperature In Countercurrent Heat ExchangerStarted by Guest_panoska_* , 18 Feb 2025 |
