I have been having some situations with one of our boilers in our plant. The boiler is a Water Tube boiler of 600 psi; we currently use a mixture of petroleum + methane (biogas) as our fuel.
The problem is that when we are trying to start it up and we in some way stabilize the boiler around 600 psi, then it suddenly increases the furnace pressure in a matter of some seconds and then it shut downs due to safety controls because of excess pressure inside the furnace. It looks like in some way it does some kind of uncontrolled combustion of accumulated fuel which results in this suddenly increase of pressure in the furnace or at least that’s one of my theories of possible reasons.
We use 50 psi vapor to atomize the petroleum. What kind of factors could create this kind of effect inside a boiler furnace? Could it be a problem with condensation in the vapor system atomizing the petroleum? Or maybe some accumulation of fuel inside the furnace that instantly ignites creating this kind of explosion?
The combustion gases are also used to heat the vapors on superheater. Could it be some kind of obstruction of the flue gases? Maybe if this were true then some gradually increase in pressure would be the effect, but we are seeing a big increase in pressure in a matters of 1 or 2 seconds like if it were some kind of explosion.
Thanks in advance. Any other important information or data can be given if needed.
Edited by Art Montemayor, 07 December 2012 - 01:00 PM.
