I am a young professional and I am facing more in depth corrosion control in boilers. My handbook refers to two different types of boilers: Resistance and Electrode.
Can you explain me the difference?
Thank you in advance!
Electrode And Resistance Boilers
Started by simobecks, Jan 09 2013 04:28 AM
boiler electric resistance
Posted 09 January 2013 - 04:28 AM
Posted 09 January 2013 - 07:20 AM
Resistance boiler is understood as Electrical resistance boiler. The latter heats water by passing alternative current (usual voltage ~200-600) through (solid) ohmic resistances, thus converting electric energy to heat.
A special kind of Electric boiler is the Electrode boiler. In the latter water is heated by conducting alternative current (to avoid electrolysis, usual voltage ~6000) through its mass. Water itself serves as electrical resistance.
This conclusion has been obtained from Web, see attached "elboiler.doc" for more references (links).
Resistance K Of ReducersStarted by Guest_Seonwoo_* , 20 Mar 2025 |
Negative Resistance Coeffecient For TeesStarted by Guest_panoska_* , 11 May 2024 |
Fouling ResistanceStarted by Guest_Mohamed_Mamdouh_* , 15 Sep 2023 |
Monitoring Of Level Control In Steam BoilersStarted by Guest_Movers_* , 14 Sep 2022 |
Deaerator Equipment In BoilersStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
