Is Cooking Chemical Engineering
Posted 13 January 2013 - 07:42 PM
Do you guys agree with this statement or that cooking is chemical engineering. I never thought of it this way myself.
Posted 14 January 2013 - 03:46 AM
By the way, a colleague used to say that house is more dangerous than factory; all these operations are realized in a limited space and also need electricity, water, fuel. You have to think of safety too.
Edited by kkala, 14 January 2013 - 03:48 AM.
Posted 15 January 2013 - 02:14 AM
My father discouraged me to follow that way and so I chosen Chemistry, and then Chemical Engineering and Process Design.
Today, 40 years later, I enjoy both my job, as Process Engineer, and my main hobby, in the kitchen!
Posted 15 January 2013 - 04:18 AM
I read an article (probably in Chemical Engineering magazine) around 1980, briefly saying that cooking is practical chemical engineering. I think it is so. I have just boiled eggs trying to be soft-boiled, which is a matter of heat transfer. Soups can be a result of solid-liquid extraction. Concentration is often realized through evaporation. If you make mayonnaise yourself, you try to avoid colloid coagulation, same for several sensitive sauces. Dehydration, salt adding, sugar adding promotes food conservation. Material mixing is widely applied. Also fermentation, when using brewery yeast. Distillation may be not applied in cooking (though widely used in alcoholic drink industry).
true enough! its a small scale engineering process
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
![]() Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
![]() Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
