Ion Exchange For High Tds
Posted 21 January 2013 - 02:39 AM
I have been informed by an ion exchange resin supplier that ion exchange can lower TDS levels in waste water. This does not make sense to me from a mass balance point of view, since the ions are simply 'being exchanged'; unless adsorption is also taking place onto the resin. I would appreciate any advice from anyone with experience with treatment using ion exchange. The waste water has a TDS level of approximately 50 000 mg/l.
Bjanka
Posted 21 January 2013 - 10:03 AM
I dont know what kinda ion exchange resin your supplier gives you that can treat raw wastewater with 50000mg/L of TDS but I can describe a bit of mine that produces demin water. Mine consists of a strong acid cation to remove cation. A weak base acid to remove anion. And a strong base acid to remove Si. Na+ and Ca2+ are taken up first and H+ is replaced into the water. Then HNO3-, Cl- and SO42- are taken up and OH- is replaced into the water. And so H+ and OH- makes water. Its like you give me one dollar and I exchange one dollar with you. You and I still have one dollar after exchange, so its still the same, just that we swapped dollars. Therefore nothing is wrong with the mass balance.
If you like to learn more, perhaps you can read the following book.
Reynolds, T.D, and Richards, P.A., “Unit Operations and Processes in Environmental Engineering”, PWS Publishing Company
Edited by thorium90, 21 January 2013 - 10:14 AM.
Posted 22 January 2013 - 09:16 AM
Also, when considering a H+ bed, check your alkalinity. The carbonate/bicarbonate will act as a buffer to changing the wastewater pH as the H+ falls off the resin and into solution. This will create a very large amount of CO2 gas.
Posted 23 January 2013 - 01:48 AM
Markymaark, the alkalinity is negligible, but thanks for the tip, I will remember it in future.
Posted 23 January 2013 - 12:24 PM
Edited by thorium90, 23 January 2013 - 12:34 PM.
Posted 24 January 2013 - 11:32 AM
TDS 2000 mg/l
Cl- 1500 mg/l
Ca 200 mg/l
Zn 400 mg/l
Which is lower that what I initially thought. My instinct is to go for ion exchange, your thoughts?
Posted 24 January 2013 - 02:04 PM
Posted 04 February 2013 - 01:47 PM
Bjanka if you still have an interest in the removal of those metal and TDS respond back. One question that was not asked as it is wastewater, is there any oil and grease present?
Posted 05 February 2013 - 08:42 AM
There is negligible oil and grease present.
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
High Temperature Low Temperature InterfaceStarted by Guest_nik98_* , 11 Sep 2024 |
