Design A Threaded Top Cover For Small Diameter Pressure Vessel
No replies to this topic
#1 Bhagya
Bhagya
  • 5 posts
Posted 23 January 2013 - 03:51 AM
Hi All,
Need to design a small diameter pressure vessel for my research experiment. As per the requirement the vessel will be exposed to 0 - 50 bar pressure difference & 30-40 C degree temperature.
Selected vessel dimensions are as ,
Inside Diameter - 50 mm
Shell Height - 10 Cm
By considering the operating conditions,other calculated dimensions are
Shell thickness - 4 mm
Welded bottom plate thickness - 10 mm
This vessel need to be attached to 1'' diameter gas pipe line from top of the vessel & during the experiments the top cover need to be open/dismantle several times to insert & remove the samples which are inside the vessel. I'm hoping to design a threaded top cover same as the attached image (which is extracted from a research paper, my design is going to be exactly the same shape but the dimensions will be different) for the pressure vessel.
would like to know what type of books/standards (ASME /BS) or any other reference materials that i need to follow to design a threaded top cover plate for this pressure vessel.
Thanks all
Bhagya
