Im involve in a gasfield development project. We are currently in the conceptual design stage and one of the concept that need to be study is JT Process. I do need explanation regarding the relation between pressure drop at choke valve and its effect to the JT Process. The case that I try to figure out is as following:
FTHP = 2500 psig
Required Export Pressure = 1560 psig
by considering pressure drop in equipments to be very small and the main pressure drop is cause by choke valve and JT valve. the question is:
1) which pressure drop we need to determine first, Choke Valve or JT Valve pressure drop???
we can see in the results section (Attachment 1) that the higher pressure drop on the choke valve & lesser pressure drop on the JT Valve; will results in:
-the water contents in the product gas will be higher.
-temperature will be higher
-the condensate flow rate will be lesser.
Can anyone describe what is the criteria that need to be taken into account when we deal with this problem. Thank you.
Attachment 1.xlsx 10.42KB
86 downloads
