Dear Friends,
I have a question regarding to the relief load calculation for a particular case that needs your help.
please find the sketch as attached.
A flash drum's liquid product goes to a steam stripper through a Control Valve(liquid level control for the flash drum).
The case to study is this CV fails open (total Cv=1100) and liquid level at flash drum loses and the two phase flow from stream S1 will go through CV to the stripper. The relief load from the stripper is to be determined.
the normal flow of S3 is 700 t/hr and at relief case the two phase flow through the CV would be 70 t/hr Vapor plus 1450 t/hr Liquid.
My question is that in this case how to determine the relief load required for the Stripper? Would the unbalanced heat method be used in this particular case?
Thank you so much.
Invssse
