Pressure Drop Calculation Through The Vessel
preessure drop calculation
#1 premjagan
premjagan
  • 30 posts
Posted 19 February 2013 - 08:52 AM
 CASE 1: when X m3/hr of gas is passing through the catalyst bed,it offers the definite pressure drop.
 CASE 2 : when X+X1 m3/hr of gas is passing through the catalyst bed, the pressure drop offered by the same catalyst bed .is now varied surely.
                         when volumetric flow of gas through the catalyst is inscreased, how can i calculate the variation of pressure drop offered by the catalyst bed vessel?
PREMKUMAR
#2 Steve Hall
Steve Hall
  • 167 posts
Posted 19 February 2013 - 11:25 AM
The Ergun Equation is a way to predict the pressure drop. If you know the pressure drop at one set of conditions, the pressure drop varies by the square of flow (double the flow, quadruple the pressure drop) -- assuming density remains constant which means this is valid only when the pressure drop is less than about 10% of the inlet pressure. For rough work, the pressure drop can be larger - say 25% - of the inlet pressure (pressure is absolute, not gage).
