I am really confused.
Does it controls (increases / decreases) Pressure? Does it controls volumetric flowrate of the fluid flowing through the pipe?
As far as I know, according to the 'equation of continuity', for an in-compressible fluid flowing through a pipe, whenever cross-sectional area decreases, its velocity should increase.
The flowrate essentially remains constant.
Why then, when the control valve position is lowered i.e. its cross-sectional area decreased, does fluid flow-rate decreases? Shouldn't its velocity increase with the flowrate remaining unaffected?
Isn't this contradicting the continuity equation?
Let us suppose that a fluid is flowing through the pipe with the flowrate -> 450 m3/hr initially.
On closing the control valve a little, we start getting the flowrate => 350 m3/hr
Where has that 100m3/hr gone. Has the pump which was pumping the fluid at 450 m3/hr suddenly suffered a loss in flow rate? because I don't think that's possible unless we decrease impeller diameter or decreased the rpm.
Please help me clear the confusion.
Thanks.
