Ethylbenzene/styrene Recovery With Vacuum Distillation
Posted 21 February 2013 - 02:20 AM
Posted 21 February 2013 - 02:31 AM
These websites could prove enlightening
http://www.freepaten...om/3904484.html
http://www.cbi.com/i...-Styrene-12.pdf
http://klmtechgroup....r rev intro.pdf
It would appear the tar sort of assists in the distillation due to the close boiling points of EB and STY. This complicates things a little. But those links provide suitable insights into the operating conditions of current plants using the technology
Edited by thorium90, 21 February 2013 - 02:38 AM.
Posted 21 February 2013 - 12:57 PM
Hi Thorium
Thank you very much for the links, the patents were an eye opener, when you said it complicated a bit(inclusion of tar) how much does it complicate things? because with in reason I can balance out the mass balance and not really count tar as a separate component. My tutor said it's fine I do that.
Now the patents have provided really useful data, but are not referred, do I just use the operating conditions from there and just provide reference that I have taken it from there, I have been recommended to look at Engineering Handbooks for certain values. But I get lost in that book.
From what I gathered, it certainly is a binary distillation method, and a vacuum one at that(because of the really close boiling point differences of 10oC, And what is more accurate the Fenske Underwood? or McCabe.
Again thanks a million for the guidance.
Posted 21 February 2013 - 01:05 PM
From this line in the first link:
"The added styrene tar residue increases the relative volatility between ethylbenzene and styrene monomer"
Well, but if your tutor thinks its possible to ignore this effect, then it will be the standard kind of calculations then.
Some useful equations
Underwood: Minimum reflux ratio
Fenske: Minimum number of ideal trays
Gilliland: Tray efficiency
Murphree efficiency: Used with McCabe Thiele
Edited by thorium90, 21 February 2013 - 01:16 PM.
Posted 22 February 2013 - 07:59 AM
thank you for that post it so clear.
I am doing the distillation of dimethly ether and carbon dioxide if you can find me some links so i can read around. I have been looking for some guidance but can not find any. thank you in advance
Posted 22 February 2013 - 09:00 AM
Wow, how many projects must one do just to graduate?!!
Nevertheless, searching google is an easy task for many students nowadays. Rmb, GIYF...
http://www.ijest-ng....no1-pp10-21.pdf
http://www.google.co...s/US20110040129
Posted 22 February 2013 - 10:12 PM
Not too many projects I assure you, but most of us are given different equipment to work on. I have been working on mine, and it's looking rocky, even different patent say different things, one say there's azetropes happening, others say we work with x amount of pressure, which is actually above atmospheric, then there is this whole issue of pressure drop, but I have already selected vacuum, anyway, since you have mentioned that there's an increase in the relative volatility(inclusion of tar), I believe that's a good thing cause it makes separation easier.
Oh Lord. It's worse cause I'm such a goldfiish at times, I select one path and then try another one, I need to learn to make up my mind.
My VLE diagram looks way too sketchy. I shall update after making progress(very slow at the moment) .
Thank you thorium, good luck tatenda with your design, are you designing a vacuum distillation column too? we could brain storm!
Edited by choudha4, 22 February 2013 - 10:14 PM.
Posted 23 February 2013 - 10:27 PM
Hi Thorium,
How do you calculate the molar flow rate from mass flow-rate in a ''mixture'' cause I just divided it with the average molar mass of all my components Mr( I am guessing it's wrong because there the composition to consider?)
Hence asking. Thanks
Posted 24 February 2013 - 12:20 AM
You need to brush up on your chemical engineering basics. Dig out all your textbooks, lecture notes and read them again.
Anyhow, this might refresh your memory.
http://en.wikipedia....ass_of_mixtures
#10
Posted 25 February 2013 - 02:59 AM
hi Thorium
thank you.. i actually shelved the design of the slurry bed reactor because of lack of information,i.e. in my country we do not have free access to recent journals and this technology is quite recent thus now designing the distillation column
hi choudha4
i am not doing vacuum distillation but i did my internship where vacuum distillation was done what is that you want exactly? we can communicate via email if thats fine with you, good luck with yours too
#11
Posted 25 February 2013 - 03:46 AM
Distillation is not a very recent technology... Access to journals is never free. You always pay for them. When you are in a university, they deduct it from your school fees... Anyway, you have internet, so you still can theoretically access journals...
Posted 18 March 2013 - 07:02 PM
Okay, I know I have come back to this much later that I ought to, but here's what happened, I believe if I have mentioned the value of the fraction of the more volatile component at the top product is low then someone could have informed that one can't even construct a McCabe theil diagram, and here I was thinking I am doing something wrong cause it looks odd, thinking that my basics needs brushing up and I was after all asking silly questions cause my doubts were in the wrong area.
To support what I have just said, I have come across a text book that says that
After that I have made this interesting finding about Smoker's equation, where I can determine the number of stages for the separation of close boiling Isomers and if the relative volatility is constant and if they are low, which fits my process quite well, your thoughts thorium? Since I do get a very large number of stages according to reference books. Hence McCabe diagram here is also impractical.
#13
Posted 20 May 2013 - 06:35 AM
I know this thread may be quite dead, but I think I just forgot about this thread. Lots of work now and following many threads so I forget which ones I havent replied!
Anyway, what I wanted to say was, although McCabe-Thiele is a graphical method, we have computers now. We don't need graph paper to draw curves now...
One can use excel to do the job. The attached spreadsheet is from Samir Khan's website.
http://excelcalculat...tion-excel.html
If you have Matlab, you can also use the following code.
http://www.mathworks...-binary-mixture
Edited by thorium90, 20 May 2013 - 06:35 AM.
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
