Dears
What are the main causes for corrosion in plate heat exchangers even if cooling water is chemically treated..
Posted 25 February 2013 - 04:18 AM
Dears
Posted 25 February 2013 - 04:58 AM
For one, the other side is not cooling water...
This might be a nice read.
http://books.google....ved=0CE8Q6AEwBQ
Edited by thorium90, 25 February 2013 - 11:42 AM.
Posted 25 February 2013 - 08:18 PM
Posted 25 February 2013 - 11:04 PM
Ahmed,
I've observed corrosion in stagnant area between the plate and the gasket .
Posted 26 February 2013 - 04:40 AM
Sir your observation is quite well, yes corrosion in stagnant area between the plate and the gasket where the temperature is high...but here we have plate heat exchanger to control the temperature in molasses fermentation not more than 35, as well as i observed pitting starts on the top of grooves (ziz zag) where two plate are in contact each other.....later on pitting converts into the pinholes
Posted 26 February 2013 - 04:43 AM
Thorium
Igot the link reply as .....
You have either reached a page that is unavailable for viewing or reached your viewing limit for this book.
Posted 26 February 2013 - 04:49 AM
Its more of a preview for the book so not all the pages are available... You could buy or borrow the book...
Posted 01 March 2013 - 03:45 AM
Dears
Ahmed,
even chemically treated, scale and corrosion still possible to be occurred, I guess no constant 100% pure water on the system. that why, an equipment, such as plate heat exchangers, also need to be cleaned at least once a year.
kindly if you can show me what is the product of your HE? one side is water, and what is another side? and on which side the corrosion occured? what kind of corrosion it is? something rusty or like scale stuff?
thank you
Posted 02 March 2013 - 03:19 AM
Dear isbarqi
here we have plate heat exchanger to control the temperature in molasses fermentation not more than 35, as well as i observed pitting starts on the top of grooves (ziz zag) where two plate are in contact each other.....later on pitting converts into the pinholes mostly pitting occured in mash side but water side also not too safe....almost after 45 days washing cycle proceed.
Spec of PHE
Description SIDE 1 SIDE 2
Medium C.Water Either Fermented Mash or diluted molasses
TEST PRESSURE 6.7 at 6.7 at
DESIGN PRESSURE 5.1 at 5.1 at
MAX TEMPERATURE 35 °C 35 °C
MIN TEMPERATURE 0 °C 0 °C
GASKET EPDMP CLIP-ON
PLATE MATERIAL ALLOY 316
PLATE THICKNESS 0.50 mm
HEAT LOAD 427 Mcal/h
Naseem AHmed
Posted 02 March 2013 - 06:28 AM
Naseem,
What is the metallurgy (alloy 316) ?
What about the quality of the water ? CL-
Thanks for your feedback
Posted 02 March 2013 - 11:50 PM
Well,, I'm not very experienced with molasses or with alcohol plant. but since you found much pitting on mash side, you'd better to check the mineral/anions content of that side. since some anions, like Chlorides, fluorides, or iodides stimulate pitting corrosion. see http://en.wikipedia....tting_corrosion.
Posted 03 March 2013 - 12:17 AM
Dear All
Can you share pictures with following info
Best regards
Once In got
Posted 03 March 2013 - 12:36 AM
Dear Breizh
What is the metallurgy (alloy 316) ? it is stainless steel 316
What about the quality of the water ? CL- could't check clorine level , but TDS < 500 ppm and pH = 7.5 to 8.0
Posted 03 March 2013 - 12:46 AM
Thanks Naseem ,
Let you investigate the CL- content , most probably too high . Let you request support from the company which is doing the Cooling water treatment or Boiler treatment in your facility .
Posted 04 March 2013 - 09:07 AM
Dear All
Good day!
Best regards and God Bless You
Ahmed Attyub
Posted 04 March 2013 - 06:59 PM
Posted 05 March 2013 - 04:21 AM
Ahmed Attyub
Dear sir
Posted 19 June 2013 - 11:29 AM
What are the main causes for pinhole in Titanium plate heat ex-changer and other probable cause of leakage having sea water as cooling media and D.M. water as other media ???.......
Flowrate - 1100 m3/hr..Pr...3 Kg.....Temp....50 C...35 C.....D.M. water side
Flowrate - 1292 m3/hr...Pr...2 kg....temp......32 C....34 C....Sea water side
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Shell And Tube Heat Exchanger In HtriStarted by Guest_Sanjayr126_* , 28 Sep 2021 |
Heat Loss Calculation From Cylindrical Tan;Started by Guest_rasprocess2026_* , 23 Jul 2025 |
