I have no experience on NACE requirements, locally being responsibility of Technological (not Process) Dept, apart from news that a carbon steel pipe should be stressed relieved above one limit of H2S content in the fluid, combined with moisture and pH. This note is because there has been no response to the query so far. Hopefully someone really knowing the subject will give a specific answer.
Well, I would require NACE compliance; it does not matter if alloy 825 is totally covered by NACE. It might show some ignorance, that is all.
NACE may require specific grades of alloy 825; or have additional requirements on mechanical properties, granular structure, etc.
Besides NACE may have special requirements on welding the internals to the vessel wall, as they seem to have on alloy 825 gaskets in <http://www.nace.org/...5a-9b6c31db1180>.
Thanks Kkala,
to be on safer side i asked vedor to comply with NACE.
some body told me verbally, that it is already NACE compliace and hence why are you asking a vendor again to comply with NACE. ( his intenstion was that vendor should not think that we dont know about MOC )
still i am scraching my head to find a answer, since we yet to get response from vendor.
