Hi !
I would like to know how to find the formula which relates temperature to the heat capacity of compounds in Hysys? (something that goes like Cp= a +bT +CT^2 +DT^3+...).
Another question is whether I can model a cracking reaction which occurs in a furnace as a non-isothermal reactor with constant heat flux supplied by the furnace using MATLAB? Then for the value of the overall heat transfer coefficient (U) in the energy balance differential equation, how can I calculate it? (i.e. what correlations are available?)
Last question is in HYSYS, when I model an isothermal reactor (by setting the inlet and outlet temperature the same), the duty calculated by HYSYS in the reactor(shown in performance tab) is changing with the reactor length (in other words, variable amount of heat is supplied along the reactor length). So, if I want to assume a constant heat flux supplied to the reactor, can I instead specify a value in the energy stream that is attached to the plug flow reactor such that the inlet and outlet temperature of the reactor becomes the same?
Thank you.
