Please help.
What does -0.8 bar pressure mean? What does -0.8 bar pressure equvalent to in psig or mmHg?
What does -0.2 bar pressure mean?
Thank you very much.
Okara
Vacuum
Started by Guest_Okara_*, Feb 10 2006 08:22 PM
7 replies to this topic
Guest_Okara_*
Posted 10 February 2006 - 08:22 PM
Posted 11 February 2006 - 01:50 PM
Okara:
This is a good student question because it is candid, honest, and straightforward. This is a good example of spotting something that doesn’t seem to make sense and asking the question – without being afraid of admitting ignorance or failure to understand. As it turns out, I believe the employment of a negative pressure is bad and misleading nomenclature used by either lazy or ignorant engineers. I believe whoever wrote that notation was trying to describe a partial vacuum and they used a negative notation thinking that the pressure scale is analogous to the temperature scales. It is not.
I am going to assume what you are dealing with are partial vacuum pressure values. If so, then there is only one accurate and simple way to talk about vacuum, in my opinion: in absolute pressure units. That way, there is no confusion created in dealing with the values and communicating with them. For example, do you mean (by -0.8 bar) 0.8 bar below atmospheric pressure (whatever that is, where you are at)? If you stated, instead, 0.2 barA (approximately) everyone would understand what you mean. If you know the value of the local atmospheric pressure, then you can quantify the exact value of the absolute vacuum pressure. Always employ absolute pressure values when dealing with vacuum. This leaves nothing to conjecture or guess.
The temperature scales are not analogous to the pressure scale because in the pressure scale(s) the value of “zero” gauge pressure depends on where you are located at. In other words, the base atmospheric pressure differs with location. This is not a factor in the temperature scales and that is why the negative values of the gauge temperatures are understandable and accurate to describe.
If you are working with vacuum and would like to have an Excel workbook that explains vacuum technology and its workings, send me your email and I’ll send you a copy of it. Vacuum readings and notation are so varied and misunderstood that I had to prepare this workbook for young graduate engineers that worked under me some years ago. This helped in training them to understand just what vacuum is and how it is measured and handled.
I hope this helps out.
Guest_Okara_*
Posted 11 February 2006 - 07:07 PM
Hi Art,
Thank you very much for the detailed explaination.
my email address is: pop_li@hotmail.com
Okara
Okara
Guest_abc_*
Posted 12 February 2006 - 02:08 AM
plz send me a copy too
my email id is
nimble_star@yahoo.com
thankyou
with regards
my email id is
thankyou
with regards
Posted 12 February 2006 - 02:28 AM
umm.. why not just attach the file to the forum?
it would work better and fewer posts also!
Ankur
Ankur
Guest_Guest_*
Posted 13 February 2006 - 08:35 AM
-I would like receiving that copy too pls,thx in advance
-just got employed in petrochemical ind
-popay73@yahoo.com
-popay73@yahoo.com
Guest_imran_*
Posted 18 February 2006 - 01:06 PM
[quote name='imrran, date='Feb 18 2006, 01:50 PM' post='4590']
I am learning about the preventive maintenence of the pumps. I have recently come accross the vaccum pumps. But to be very frank I am confussed about the basic working of the vaccume pumps. I have searched a lot for it on internet but still there is no progress in my work. If someone can help me understanding the vaccum pumps. My mail address is izk78@hotmail.com.
Guest_imran_*
Posted 18 February 2006 - 01:09 PM
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
![]() Vacuum SystemStarted by Guest_panoska_* , 21 Oct 2024 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
Air Flow Into A Tank At Partial VacuumStarted by Guest_rajaking666_* , 25 Jul 2024 |
