Hello all,
I have been set the task of designing a heat exchanger for use in a cumene production process and am unsure if my method of carrying out the task is correct. The problem statement outlines how the conversion reactor is cooled using dowtherm, which enters the reactor at 200C and exits at 210C. The dowtherm is then itself cooled by generating 15 bar gauge steam using a shell and tube heat exchanger and a waste heat boiler. After carrying out an energy balance over the reactor, along with modelling the process in Aspen HYSYS, i determined the heat to be removed from the reactor (in order to maintain a constant outlet temperature) is -1.386 E+6 kJ/h. There are little design parameters for the heat exchanger other than a tube velocity of between 1 and 3 m/s is to be achieved. I have assumed a total heat transfer coefficient, U, of 200 kJ/h.m^2.C for a shell and tube using dowtherm from Coulson's. I have determined the steam outlet temperature, 201.41C, from saturation tables, however am unsure what the inlet temperature would be? I have assumed the dowtherm to be flowing tube side however am not sure if this would be best? Should i be getting a positive or negative LMTD for the arrangement? I am to choose my own shell and tube size, arrangement length etc...
Any help would be much appreciated.
Regards, Oliver
